Moto Doc Stunt Shop WEBSITE IS UP!!!
http://www.motodocstuntshop.com/
taking orders/deposits on frames and cages
CHECK OUT OUR SITE!!
we are still under constuction..
will be updating daily..
i built the site really quick so bear with us it will be improving.
Site looks good
hell yeah
Originally Posted by DWJmoto
Site looks good
Originally Posted by Duane S.
hell yeah
Thanks guys....my first site.. It will get better
Hell yeah bro sites neat!!
thanks guys
feedback is great!!
im a metal fab guy not a keyboard guy..so you guys let me know if there any things you would like to see on the site.
bump...check out the site guys...
we need some orders!!
had a long day of r&d on the cage and the frame sunday!!
my cams were all dead..spent to much time gettn everything else ready for the session slam forgot the chargers
had a few other guys at the lot taking vid and pics so i'll try to get some footage soon.
learned a bunch, no prob with lowsiding drift..and gave it a bunch of really hard hits..
lowsided it out of a cir and no problem at all..
so i pulled it up rolled along around 10 mph and let the front end start to drop and gassed and jumped off..bike stayed at 12 swayed back and forth slamed really hard on the left cage then flopped to the right side.
cage took it all..we did tear a damper, but kinda was looking for that..the design was for 3 damper and was trying to get away with 2 but 3 is what its going to need..
the movement you get with only 2 dampers i like but is only good for compression hits ..
so all in all the cage responded to the testing just as hoped..have already started to mod the cage for the 3rd damper and will post pics soon..
thanks to all you guys following our R&D.
our production cages will be made from 4130 chromoly 1in x .120 wall
ordered a few sticks today..
this will make the cage alittle lighter aswell as stronger..
bump
updating the site daily!!!
check us out..
qoute from the site
Just like the subframe on your bike the over and over input that is sent into the bolts that connect it to the main frame will over time enlarge the thru hole in your subframe and main frame, there for not creating a strong movement free connection.The mounting systems on all the other stunt frames on the market will have these same effects. Our mounting system does not input any load into the mounting bolts and will never enlarge the mounting point bolt holes!!!There for staying tight and strong
