Less than 1 minute ago
\r\n \r\n support the whole thing from the bottom of the engine. then lift the frame off the engine. take the forks off first, the frame is really light.\r\n
ny450's f4i 2011 build progress/help thread
\r\n \r\n makes sense thanks mike for always droppin the wisdom when i need\r\n
\r\n \r\n good progress man! cant wait to see how it comes out\r\n
\r\n \r\n subscribed\r\n
\r\n hey... that me Quote: \r\n
![]() \n \nsubscribed!!\r\n
\r\n \r\n got swingarm off but engine isnt budging..both swingarm bolts obviously out, both upper engine mount bolts out, ...is there anything else thats keeping this all together? does the lock ring on the throttle side engine mount bolt need to be removed? (mini version of the swingarm lock ring, which was A BITCH btw) stumped, i figured the frame would lift right off\r\n
\r\n \r\n yes on the right side on the frame should be all the adjustments to the motor i got mine off witha stock 12mm bolt i clamped some vise grips on also there i are lower motor mout bolts in the front that have to be removed hope this helps!\r\n
\r\n helped alot, will do tommorow first thing...thanks!!\r\n
Quote: \r\n
