tokico 4 piston on HHD bracket
my buddy is runnin gsxr calipers in his dual 4 piston bracket (fti) you should be good to go. just whatever side is needed
Originally Posted by BIGDIDDY
its a dual single caliper bracket with the 4 piston adapter. the bolt pattern looks the same as a 4 piston nissin.
So basically just use a Tociko from a GSXR instead of the Nissin everyones using from Hondas? I'll have to check that out for fitment
Will work
Originally Posted by GIL with 1 L
Will work
sweet.... now my question is do i have to shave down the brake pads like you have to do on the nissin pads??
will a tokico 4 piston off of a gsx-r work with the HHD bracket??
you have to be more specific, Hohey makes many different brackets that use different calipers. Im pretty sure the answer is no, as I have not seen one from him that takes a Tokico 4 piston...
