Bigger Rotors?
\r\n \r\n i dont know about the 14 rotor but i do know the zx11 d model rotor bolts right up but i dont know if your caliper is far enough out , if not the newer zzr rotors are a little smaller than the zx11 and they bolt up too\r\n
what year\r\n
\r\n Originally Posted by mdub4life29\r\n View Post\r\n
what year
lol we were just discussing this the other day. think it was 93-01 but nobody was really sure\r\n
\r\n \r\n 14 rotor does not bolt up, tried and it doesnt fit
\nFor your windscreen 05-08 are all the same\r\n
\r\n Originally Posted by MikeM\r\n View Post\r\n
93-01 ZX or ZZR1100 100% sure will bolt up on the rear Kawi wheels\r\n
\r\n \r\n sick! i\'ll have motomaster send me a zxr400 rotor then.. which years? and then offcourse i should get the hohey additional bracket, right?\r\n
\r\n Originally Posted by da Liks\r\n View Post\r\n
That wont work because the Hohey brackets are designed for 250mm rotors...If you use his brackets with a 240mm rotor you will still have to trim pads and wont get full contact
\nIf you want to stick with your Hohey setup, and get a bigger rotor without having the buy the expensive Star rotors. Get a OEM or Motomaster ZX11 rotor(250mm) and the adapter brackets...\r\n
\r\n Originally Posted by JohnnyP\r\n View Post\r\n
\nwhat about f4i with fti dual quad bracket? is there a rotor i can use?\r\n
\r\n Originally Posted by i_throw_nickels\r\n View Post\r\n
Not without moddifying your FTI bracket to accept a bigger rotor
\nThis is how I modded mine
\n\r\n
\r\n \r\n I\'m running the ZX-11 rotor with my set up.
\n\r\n
