10-26-2010, 05:37 AM
Click Link to go to Naarden Online Store: http://www.naarden.biz/products.asp?cat=484
from October 21-Oct 28.
Celebrate Vortex�s AMA Superbike & Sportbike Titles
Tubular design to ensure stability measuring at 1 �� diameter with four 4�� soft wheels wheels with bearings for easy pivoting motion.
Axle and wrench holders located on arm to help keep part clean while removed.
Supports from steering neck to allow easy access to front wheel and other components.
Lifting arm is removable and stowable for a safe working environment.
Easy disassembly for easy shipping and storage .
Font stands are not to be used without a rear stand for stability.IMPORTANT: Bike specific pins are required for proper fitment into the lower triple clamp. Please use drop down menu for your bike.See FRONT STAND PIN APPLICATION CHART for correct pin sizing.All stands come with pin FP050, if needing adapter FP051 or FP052, select it in the option below.
Group BUY orders will be shipping out November 2
sorry I ran around the block to ask the question
