Less than 1 minute ago
\r\n \r\n one more thing, the RPM gauge does not move when bike is switched to on position\r\n
cbr 954 lost key/ignition bypassed..
\r\n \r\n They Can make a key using the number code on the ignition for like $10\r\n
\r\n \r\n I\'m fucked now,Someone tolled me there was chip in the key or some shit and your fucked if u lose it..so i kinda had to hit the original ignition with a hammer to get it off,the bolts holding it were striped...then i found out that us bikes don\'t even have that..\r\n
\r\n \r\n bike runs
what did you do to fix it??? \n \n \n \nIf you still have your old ign. you should see some digits \non the base... PM me the digits and I\'ll send you a key ... \r\n
\r\n trick is in the diode...i wish you tolled me that before..Quote: \r\n
09-23-2010, 04:54 AM
lost the only key to my 954..decided to buy a new ignition key, and cap off ebay from china,tried wiring up the 3 wires, did not work, then i figured that there was no diode in the ignition switch, so i buy a 3.9 diode zener from a electrical store, and i got the speedo to light up and fuel pump is priming,
but bike wont start. all i did was take the two red wires connected them to one end of the diode, and the pink to the other end, just to see if i can start it. but nothing. is it possible to get the bike running like this? is it possible to burn the computer if i was careless with the wires? i got two computer but i don't know i might have killed both before i figured the right way to hook up the three wires that go in to the ignition. can anybody help?
