Threads: 66
0
so i bought one used it once and i am not sure if i like it. its easy to use but i burn and churn through canister of brake fluid. my question is when you pump it from the handgun and it goes into the little resovoir cup can i use what was bleed out from the cup as long as is its new brake fluid? it seems like such a waste not too. will i be contaminatin the fluid if i do this?
Threads: 0
0
i normally dump mine but really as long as you wipe off the bleeder and clean out your cup good i see no reason to not use it.
Threads: 66
0
sweeet thanks for the tips
Threads: 66
0
reusing the break fluid that comes out usually has air in it lil bubbles plus it usually pulls old fluid out with it
thats what I think
