adjusting secondary butterflies on 03-04 636
\r\n \r\n try plugging in a different ECM and see how they work. \r\n
\r\n \r\n adjust the poop levels...\r\n
\r\n \r\n ecu? did that.
\r\njust put a new set of throttle bodies on last night and my bike is still doing the same thing. and even crazier than that, the new throttle body secondary butterflies arent closing as far as other peoples 636 that i\'ve compared them to. and the old throttle bodies did the same thing.\r\n
\r\n Originally Posted by loogie\r\n View Post\r\n
i\'m about to use this bike as a toilet if i dont figure out the problem\r\n
\r\n \r\n Bring back the F4i!\r\n
\r\n Originally Posted by ATL Darrick\r\n View Post\r\n
swap ECUs and TBs niggg you got extras or need some??? LMK\r\n
ive swapped tb\'s and they did the same thing.....no way they have the exact same problem, plus if the tps was out i would have more symptoms and the bike would run like ass. i put in my old ecu but that bike had the same problem as this one, but everything is fresh on the new one. so i am unsure that the other ecu i tried was 100% working right.\r\n
\r\n Originally Posted by J Blox\r\n View Post\r\n
Bring back the F4i!
poop nigga\r\n
\r\n \r\n i just need to know if you can adjust the secondary butterflies. if they arent seating all the way down like they should, then i have a huge vacuum leak, which in turn could be causing a weak idle pull.
\r\nat this point i got to start eliminating one thing at a time.\r\n
\r\n \r\n heres a thread on removing themlooks like they are worthless anyways??
\nhttp://www.zx-10r.net/forum/showthread.php?t=51847\r\n
