05 636 radiator fan! Help
05 636. Need help with radiator fan. My fan doesn't work. Is there a fan fuse? The wires are good and the connection under the tank is good but the fan doesn't work. Even over 230'F it still doesn't work. I need help locating the fuse for the fan. Is there one?
on the 03 04 there is a fuse box under the seat and should be marked fan and should be a 10a fuse
Oh yea I'm a dumbass forgot about that under the passenger seat. The fuse is fine though looks like I gotta get a new fan. Any alternate fans that work better or stock? And what's the easiest way to get to the quick disconnect for the fan? Or just gotta take off the whole black plastic box on top ?
did you take a test light to the fuse to see if there is powering going throw it? you can take the fan off and hook it up to a battery charger for a second and see if it works.
I'm gunna try that fan tomarrow
So I tested the fan and it spins perfect ! But it won't turn on at 230'f ? So if it's the thermostat where would I check and how would I check it ?
Thanks for the help so far
Why not just bypass the factory wiring by running it to a switch?
That would be awsome but I hate electrical work and uhh all that stuff is in one big ass bundle of wire and tape I won't be able to figure that out for sure. Where does that main wiring harness go ? To the rear seat to the fuse box or to the damn battery?
it looks like a baby ferret is crawling down her cleavage
Does anyone know where the temp sensor is located at??
