Threads: 2
0
What gearing do you have on your bike?
I'm running a 50 tooth on my 03/04 636. But I have been considering going up to a 55 or maybe even a 60.
Threads: 9
0
55 0n 03 04 636..Money
edit: my bad didn't see it was in female stunters
Threads: 4
0
I run a 60 on my 636, it was hard to get used to because I rode stock, then 54 on my F4i, but I like it now.
Why are you wanting to change?
Threads: 13
0
64 and 3 down on my f4i ,,, thats money !!!!
Threads: 9
0
on my 03 636 I run a 52 and 2250-2500 rpm. In the end though I think gearing and rpm is dependent on your body weight, position, and amount of aggression you ride with.
Threads: 0
0
60 and 2 down !!! F4I 4 life !!
Threads: 0
0
i think i'm 50 or 52, i'll double check when i get home, and i run my idle higher at 3-3500, i run even higher depending on what i'm doing.
Threads: 6
0
60 tooth on rear on my 03/04
Threads: 1
0
54 rear on my k3 fixxer 600
