12-29-2010, 08:47 AM
cool thanks
GP tech hand brake/clutch reviews
cool thanks
12-29-2010, 11:37 PM
12-29-2010, 11:56 PM
12-30-2010, 05:54 AM
12-30-2010, 06:07 AM
12-30-2010, 03:31 PM
this year i have been using:
12mm Motomaster/Magura master, 80" Motomaster steelbraided brake line, Hohey DC 4piston bracket with a rightside Nissin Caliper, Motomaster Rotor, SBS carbontech brakepads, Motomaster brakefluid. For the footbrake, stock kawi caliper, SBS carbontech brakepads,MOtomaster steelbraided brake line. for the front: Brembo 19x20 master cilinder, Motomaster lines and fluid, MOtomaster Rotors, stock calipers, SBS Roadsinter brakepads. for the stoppiebike i use the same, except i use a gsxr SRAD 16mm axial master cilinder..
12-30-2010, 03:52 PM
12-30-2010, 05:03 PM
12-30-2010, 06:22 PM
cool.. thanks for the info man.
. i'm gettin rid of my dual single pistons in favor of a four pistons setup. i was thinkin about continueing to run my brembo 16. do you think i should get a 13 instead? my problem is my current brake is really strong, but has an on/off feel. what you think?
12-30-2010, 06:26 PM
