my 636 wont start ...
ok i blew my motor on my 636 and bought a motor and a frame.. and i pretty much switched everything over to the good motor and frame... but i used the same wiring harness that came with the motor... and i just got everything hooked up and the bike will prime but when i hit the start button theres nothing any ideas?... anything will help... thanks
put gas in it!
does it crank?
Check kick stand sensor & tip sensor
lol theres gas... and no... no crank at all
sensors!
most likely the kick stand sensor.
clutch switch, kick stand switch, tip over switch
i took out my tip over sensor... checked the kickstand wires and everythings good.. wheres the clutch switch at?
Quote Originally Posted by suicidl
the 2 wires that went into the stock clutch
do they come off the front of the harness? if so i didnt see anything that looked like it would plug in to the clutch switch
How do I do that lol
Quote Originally Posted by WEnis
paper clip or connect the wires together.
I'm confused lol
