07-08 ZX6R Swingarm On 03-04?
I posted up a couple links on BS forums for you. Just follow the 05/06 swap but replace 05/06 parts with 07/08
you need to use the linkage from the 07/o8 and it should fit just fine
Quote Originally Posted by !!A2K!!
no....im pretty sure they are the exact same....the only thing diffrent in them is the design on the right side of the swing arm
yep
Quote Originally Posted by mofat01
Thanks for the links. I see that the links have to be spaced to line up correctly. So for anyone else attempting this swap, first thing you do is space the swingarm correctly to line up the chain then space the links so they are straight and do not bend when you tighten them down. I used all of the linkages and shock from the 07-08 also. The 07-08 swingarm is 1 inch longer than the 03-04. The 05-06 arm is 1/4 inch longer. The 07-08 arm is different than the 05-06. I took alot of measurements. Where the dog bone links connect on the 07-8 arm is over 1/4 inch to the chain side more than the 03-04
Quote Originally Posted by SHANK
Madman Motorcycles holla...
looks good glad u got it ... that tank is still at my house btw lol
Anyone know if I can run the 0304 shock with 08 swingarm?
no gotta run 05 or newer
