F4i Clutch Arm Mod ... Must Have
you roll it up when you ride? Almost caught a finger the other day. Don't even want to think about that.
And I will do this mod tomorrow. But with a swivel end since I have access to all the rivets and fasteners I need. I will let you know the difference. I'm workin on SS and spreader coasters and my finger cramps a little. So it's perfect time to see. I will post pics also.
when I did mine I made it 3/4 longer and it's very nice and easy to pull
Sean... Old ONE but good to remind everyone!!!!
But don't forget that everybike can't be modified like the 600rr and it's more efficent to cut and weld and extention on the arm! But that looks pretty good..!
Not Everyone Has The Ability To Weld Frankie:Sad.bye:
BUT I JUST DID IT TO MY F4I SO I FIGURED I WOULD POST IT UP OVER HERE ...
WHEN YOU GONNA RIDE AGAIN ??? I HAVE SOMETHING FOR YOU .
I should have my cage back on tomorrow, Ian (Sickinnovations) said my stuff was shipped and I calculated tomorrow (WED) as the day it should arrive..I'll be riding as soon as it comes in!
what advantage do you get from this that cant be acheived with an msr or moose easy pull lever. how much easier do you need it to be? not hatin just curious cause i might try it!!!!http://stuntride.com/vbstunt/images/smilies/Sad.bye.gif
shoot ill try it
It Gives U Extended Leverage .... + And Easy Pull = Gangster Butter Pull ...
comparing this to a moose it will add 30 - 50% easier pull for the clutch. There was a Stuntlife thread a few years ago in reference to this and (guessing) but the max extention for the maxium effiencency was like less than a 1/2 inch extention of the arm...but when done properly it was absolutley the best mod!
But it can't be done on some bikes like the 600rr it's cannot be done. The 636 is real easy!
