01 f4i rebuild
Real nice, im also in the process of rebuilding an 04 F4i, keep us posted brother
Looking good so far. Cant wait to see it finished.
Some progress has been made. I got the motor mounts re threaded, new bolts, had my grandpa make me new spacers and sliders for the cage, extended the clutch arm by around 1/2 inch, installed fresh head bearings and got the motor in the frame.
I know you all are dying to see some progress judging by the number of comments lol. Anyway I'm getting things done little by little.
that 900rr wheel is sick, any special spacers needed for it to fit?
The bike came with that rim when I bought it. It was missing one spacer between the wheel bearing and the cush drive bearing which must have caused the wheel bearings to go bad. From what I saw on ebay the spacers look the same, however you will have to use a 900rr cush drive and your current sprocket won't fit. just a heads up.
Moar progress
Looking good!
Where ya at with this now? Shots of it complete?
Been done for a long time but I didn't update due to no interest. I've already blown both fork seals, scratched the crap out of frame and swingarm etc lol. But that's what happens when you're putting in work.
