Vic's 03/04 half steel frame RE-build
#31
Looking good so far! Imma have to scoop up a steel frame after I trash mine
Thanks man, steel frames are sick. i can't wait to try it out.
Got some more work done. chopped exhaust and mounted. radiator on. front brake calipers on with new pads. vortex clipons. new trottle tube and grips. and all the stuff on the bars mounted.
More work done today. i wrapped the forks in black duct tape. i don't think it looks half bad. rear sets on. NDC bracket installed. Im having trouble getting it to sit right. I ground down the lower screw on the adapter, which helped a little bit. The thing is the rotor screws are still hitting the back of the bracket.
Should i take the shell off and grind down the heads of the bolts a little? the wheel will spin, but it still hits. any advice?
and yes i did the other one i just forgot to take a pic
I see where you have a ndc customs bracket on your 03 04 swingarm??? Did you have to special order that?? I went on there website and they only had it for 05 06 swingarm
http://ndcustomz.com/index.php/parts-accessories/brakes
look on the right side. the bottom one is for 03/04
Great job! Can't wait to see that in one piece
Found it....thanks bro!!!! Killer build by the way!
thanks man
So i Finally got oil in it and all the liquids it needed. i started it up on the second or third try after i realized i forgot to plug in the injector plug i think. the one behind the radiator on the front of the engine. i took it out for a test ride and the triple tree stem was loose so hopefully i took car of that. also one of the bolts broke off in my vortex clip on so now i have to figure that out. the chopped exhaust sounds pretty good too.
do you roll stoppies at all?
