Threads: 10
You want to wrap around the sides and onto the back so it doesn't lift. On the bike you won't be able to get it around the sides. The little curves and corners that you don't notice will be the hardest and you need to stretch it to get a good fit around them
Threads: 10
how not? just leave enough to wrap take the panel off and wrap em around the back??
Threads: 11
^^thats what i was thinkin and see few videos of guys doin um on the bike, i think itd be way easier and require few less hands but ive never done it so idk, curious to see how it goes tho.
Threads: 38
Loosely mounted on the bike.
Whatever prep, painting, etc that you do.. Remember, the adhesion of your wrap is only as good as your prep.. So if its a shoddy primer job, the wrap will fail
Threads: 10
i wonk in a body shop i sprayed em and cleared em already so the surface is mint
Threads: 10
Gunna do em tonight also wrapping my forks to match... Took a ill longer then I thought it would for the wrap to get here I'll post up some pics of how it goes...wish me luck lol
Threads: 6
I have a couple homies that work at chicago wraps that can do that shit in their sleep, and for cheap
Threads: 2
Good luck homie, anxious to see the outcome!
Threads: 5
Havent personally seen it done but ive watched vinyl wraps get put on on vehicles on T.V. from what i can tell all they use is a heat gun and some soapy water in a spray bottle. Remember one guy saying that he mixes water with Johnson baby shampoo...apparently works better? Im intrested to see how it goes, i was thinking of doing a few parts on my bike.
