Anyone ever seen this happen??? :(
Originally Posted by broham
I don't have an f4i, so I'm having a really hard time picturing where this mount is located, but could it be that your chain was too tight? When the rear shock compresses, the chain tightens
Thats a good point. When it was cranked down and you tightened your chain it was set for that height, but once you loosened it a few clicks it might have put to much tension on your chain, although I don't see how that would rip out the motor mount.
I've heard of a tight chain breaking a case open. If your chain is tight with no weight on the seat, then when you sit on it, it'll pull the front sprocket back.
And then imagine when you hit a big bump and everything compresses more.
Yeah I guess it does sound pretty possible. Wonder if that's what happened.
I thought Honda's were indestructible...must have been an anti-personnel mine in the highway to do that to a Hondurr lol
cause you're fucking fat!!:lol
it probably just got weak over time from all the hard riding until it gave way!
lmao shut your mouth joe...your in the "nigga got fat" club also hahaha
or just the fact its 10 years old...... and a f4i
The strength of the metal will actually stay the same when heated as long as they let it cool naturally and did not artificially cool it down after powder. Yet honestly i still have no ideas how this would happen. Maybe the metal was just weaker than normal over a period of abuse and that was the final straw
