Let's see some pics of custom tank builds
Originally Posted by ReCkLeSsRyAn
I don't weld cuz I dont have a welder I just do fab mainly and have my friend weld it at his shop
I was referring to graveyard. Lol.
LOL yeah jake just hit me up man i got caps in and check valves. This is the check valve i'm refering to Ryan http://www.cyclegear.com/eng/product...lve/web1007504
Here's mine.
sick. anyone in fl wanna do my tank for me?! lol
U put bring in the tank for support when removing the whole top?? How are u putting in the check valves? I have the same cap as the green tank u posted
You need to extend the tank vent tube all the way to the top and put a check valve on it, if not the tank pressurises or if the vents to low it will piss gas out the overflow
Flat tank 4 life
Yep......gotta vent my tank all the time, manually. I haven't had an issue w/ it causing any issues. Just crack the cap and shut it down, just prior to a ride.
Flat tank 4 life
Thru the tank or inside?
you'll need to re-enforce it if you go flat top. like this
No pics of one on an f4i I have a tank and want to try it bit not to sure bout all the extending vent hoses and must do stuff
