1998 900 rr
Originally Posted by 900rrstuntrider
ok since no one can use alittle common sense. the odometer says around 10,000 its had a sprocket on it for the last 4 years so im sure in reality the actual milage is like 8,000 or less. im sure 'most' people on here know that a sproket changes actual milage. the bike has never been "wrecked" it's a stuntbike it had been dropped with a cage on it but never wrecked.
Glws . This cracks me up everytime someone post up that the actual mileage was less due to the sprocket . Imo the motor thinks it went that far and the motor will be worn accordingly and if its a stunter it was some real hard miles . Personally I just disconnect my speedo once I gear a bike
with dropped gearing doesn't the motor have to turn more rpm to achieve the same speed? glws always loved the 98/99's
also an 17"f3 front wheel is a great upgrade over the oe 16"
