Threads: 3
i have a hohey dual caliper bracket with a 954 right front brake caliper for my handbrake and also have the left front caliper just sitting my the shelf and my question is would i be able to rock both dual calipers with the stock rotor? (once i get the adapter bracket)
Threads: 18
Ya it might not grab as much pad with a small stock rotor though but you should be fine
Threads: 3
what do you mean not enough room??
Threads: 15
Meant to say two FL's sorry about that
Threads: 3
so if i run an FR and an FL ill be good with the stock rotor?
Threads: 8
I believe u have to run trimmed pads without the big rotor
* just read up there that he needed no trimmed pads... but according to the site u have to trim pads without big rotor ... so im confused.. i have a big rotor kit and replacing it expensive so i wouldnt mind running a stock rotor.. just dont wanna have to buy trimmed pads...
Threads: 3
yea thats kinda where im at i have a 954 dual caliper in my garage just laying there and i want to put it to use but want to know if itll fit without the big rotor
