Threads: 4
Do i need subcage with a-town custom round bad with subframe brace, or would the a-town combo be enough?I ride an 05 636.I heard 05 subframes break easy so just trying to find a different approach or maybe possibly order a steel subframe?
Threads: 21
You still need a subcage. The Atown subrace combo is good ive had it for a couple months now with no problems, but if you have money for a steel subframe get that instead.
Threads: 36
Hit me up for a subcage when the time comes
Threads: 6
is you're not gorilla scraping you will be fine without a steel sub frame having the sub braces. A sub cage is more to keep your passenger rear sets from snapping giving you a more solid footing.
