Less than 1 minute ago
2 Masters to 1 Reservoir with a T- Rowdy!
\r\n \r\n I was having problems with it leaking at the fitting. Need to find a better barbed T. Doesnt the little bit of air that you have in the reservoir flow back up the line when you wheelie?\r\n
\r\n \r\n i was planing on doin this to my bike, puttin resi in igntion hole. less clutter. was worried the T fitting might let the fluid swet threw, anybody have that problem by any chance??\r\n
\r\n \r\n I\'ve capped my reservoir hose before with a plug & didnt even run a reservoir. As long as there is no leaks & everything is plumbed right & bled...shouldn\'t have any issues.\r\n
\r\n \r\n good idea, i might run this setup if i change my f4i front master
\n \r\n go to any youtube video, hit pause, go to sec 0 then press left arrow followed by up arrow ... there you go youtube snake Quote: \r\n
\r\n Damn it does. What the hell\r\n
Quote: \r\n
08-02-2012, 06:50 PM
Anyone run this setup? i think I saw rowdy had it. Having the front brake and hb run to 1 reservoir. Problems with this? Im thinking if you boiled the fluid on one then both brakes would go out?
