07-21-2012, 05:35 AM
I bought a project f4/f4i fully converted bike to make a lot bike but can't get it to run. Motor has compression, fuel pump turns on but I can't get any spark. I am tired of trying this and that already so its getting parted out. List of parts are as follows:
1). 2000 cbr f4 frame with clear title - $650+shipping
2). F4i motor w/ good compression. No starter - $350 as is!
3). F4i guages - $150+shipping
4). F4i headlight - $150+shipping
5). F4i split seat Subframe - $200+shipping
6). F4i front seat - $45+shipping
7). F4i rear seat - $75+shipping
8). 900rr front end (forks w/good seals, front wheel no tire, rotors, calipers, brake hose, upper and lower triple trees, and stock clip ons) - $350+shipping
9). F4i upper fairing stay - $85+shipping
10). F4i split seat tail fairing - $100+shipping
11). F4i rear wheel no sprocket, hub, rotor, or tire - $100+shipping
12). F4i swingarm - $50+shipping
13). F4i left front rearset bracket with shift linkage and kick plate no lever, no peg - $50
14). F4i right front rearset bracket w/kick plate no brake lever - $50+shipping
15). F4i brake lever $25+shipping
16). F4i shift lever $25+shipping
17). F4i split seat battery tray - $40+shipping
18). F4i tail-light $35+shipping
19). F4i gas tank with a minor dent or two clean no rust $100+shipping
20). F4i fuel pump - $150+shipping
21). F4i aftermarket gas cap with key $25+shipping
22). F4i wire harness complete except no relays $150+shipping
23). F4i rear shock - $45+shipping
24). F4i left passenger rearset with peg - $35+shipping
25). F4i right side passenger rearset with peg - $35+shipping
26). F4i left side clip on switches - $40+shipping
27). F4i right side clip on switches - $40+shipping
28). F4i throttle cables - $25+shipping
29). F4i rectifier - $50+shipping
30). F4i stator - $100+shipping
31). F4i airbox - $50+shipping
32). F4i rear seat linkage with cable - $35+shipping
33). F4i left side ram air duct - $25+shipping
34). F4i right side ram air duct - $25+shipping
35). F4i smoke windscreen $30+shipping
36). F4i rear rotor $35+shipping
37). F4i sprocket hub with cush drives - $25+shipping
38). F4i exhaust header stock - $50+shipping
39). F4i spark plug coul set - $50+shipping
40). F4i front seat latch - $10+shipping
Pm me for pics if needed...
