636 shock upgrade?
Search on my iPhone doesnt work and google sucks so I'm looking for an upgrade my shock is all the way tightened up but when I do a bunny hop it scrapes like hell what do u all recommend I was thinking 09 but what does that require??
how much do u weigh? Im 250lbs and bunny hop my 04 and never bottom out my shock, even from close to a foot on my hops... u riding an 05?
Ya 05 think my shock is just old I only weigh 170
might need to be serviced and new fluid added possibly? have u tried to adjust the settings of the shock? there are two adjustments, one for compression and one for rebound
http://stuntride.com/vbstunt/showthr...ighlight=shock
Thanks mini that's eye opening lol well my shock is adjusted all the way to hard and is softer than any other bike in my shop just lookin for opinions on a stiffer ride
Are u adjusting ur spring preload? Or just the clickers? There's 3 dif adjustments.
3?? I thought it was the bolt and the flathead that's all
09 zx6r's bolt up fine. but sounds like your running no pre load
Preload is which adjuster?
