MotoDoc Frame/Cage combo**NEW**
HERE IT IS GUYS
been doing serious r&d on the frames and rubber damping cages for little over a year now..and learned alot.
here's what weve come up with from the r&d of all our older stuff.
our new frame/cage system uses the same rubber damping tech MotoDoc brought to the stunt world last year. but we have learned alot and are improving a already great system. we have built into the frame the lower mounts for the cage and linked it to the main frame in two places to add strenth to the cage and stiffn the already more ridged chromoly frame.
we added a non rubber mounted mount to the rear of the cage to limit movement in hard hits. these swingarm mounts are compleatly new aswell (see pics below}pieces are machined to locate into the allen adjuster and nut of the swingarm pivot bolt thus taking all the load off the thru bolt and putting all the load into a much stronger area the swingarm bolt.
the motor mount bolt on this system does not double as a cage bolt. so no more bent motor mount bolts...
you can also run these soild by removing the dampers and installing soild 1 in spacers!!
stand alone cages are $450
cage built into a frame $400
Looks siiiiiiick dude.
god thats beefy
Damn that looks hella crazy Haha nice work buddy!
looking good.. DOC!!
What's it weigh over stock?
nice. looks stout MD.
thinking the same thing
genius....
Very nice!!
