Threads: 5
The race way per say is block offs on the valve cover and a filter on the crank case... The stunt way is venting the crank case threw the valve cover... Like in rahs pic...
Only other thing is there is a vacum line on the throttle bodies that you got to plug... That normally works the pair valve he replaced... And block the open holes you leave on the air box...
Threads: 5
I don't know anything about the extra stuff on the ca models... But that little thing in your first pic is the pair valve.. its vacuum controled on the 03/04s so there is a vacum line that isn't plugged in when you removed that... It should be sitting right on top of the valve cover when that valve was at...
Sorry I don't have any pics
Threads: 1
You remove that lil filter and all the hoses connected to it .. The one marked with the blue dot should go all the way to the throttle bodies, disconnect it and cap that port on the throttle bodies .. And on the tank there are 3 ports in the back, you need to cap the middle and the right one and BAM just like other states bike
Hope I explained it clear enough .. Sorry no pix at the moment
If ur ever in Ventura I could help u out with it
Threads: 1
thanx a whole heap mon....i think it's pretty clear...this state reg is bullshit...lol...always makin shit more complicated than it needs to be...thanx for the help tho guys...i'll post a new pic on Sat to see if i did it correctly
Threads: 1
well it can't get any clearer than that jordan...thanx alot bro
Threads: 1
oh yea and like SBxFLYHIGH said, i also capped the port that was connected to that cali filter thing
Threads: 1
ok, now i have a new dilemma...ScarryJerry said, "if you take it off on the ca model after 500 miles your engine will blow. It is how the government made kawasaki rig them so people wouldnt take them off."
Can you guys please help me out...I'm gettin so frustrated with this CA bullshit now...Much Appreciated fellas
