Less than 1 minute ago
\r\n \r\n That\'s very confusing ?, there juca.........
\nI don\'t understand what u are asking !\r\n
Quails
\r\n \r\n If the spread is the same then I don\'t see it being any harder than normal\r\n
\r\n \r\n Are you asking since its lighter if it will have the same knockdown power as a heavier load?\r\n
\r\n lets make it clear :Quote: \r\n
\n \nknockdown power will be the same as heavier load knockdown power? \n \n@Ryan: eh that\'s the point,no spread isnt same,skeet spread on some distance (lets say on 50 ft) will not be wide as regular cartridge spread. \n \nand one more question,with skeet i\'m gonna be able to kill the bird on longer distance then with regular cartridge?\r\n
\r\n \r\n I would assume that the kinetic energy(knock down power) would be greater on the smaller round since it would have less resistance. If its holding a tighter spread then you should also be able to get better distance out of it to.\r\n
\r\n \r\n adjustable spread choke on barrel!! most game shells with low brass work just fine with quail/ dove. skeet shot tho im not so sure, never used it. we use the same shells we hunt with to practice\r\n
\r\n i have adjustable spread chokes on my fathers benelli,but not on my beretta Quote: \r\n
![]() i have 1/2 and full choke...fixed\r\n
\r\n \r\n use 7 1/2 shot, or 8 high brass for quail you dont want to destroy them.
\n \nmodified choke. \n \ni hunt mostly small game that\'s what i use\r\n
\r\n i used 1.5 mm 1 1/4 dispersante as my 1. shot and for second i used 1.7 mm 1 1/4,damn i cant understand,can you tell me shot size you use in mm?Quote: \r\n
\r\n \r\n ill look when i go home, what the shells say.\r\n
