07-25-2011, 08:33 PM
Ok my front wheel is rubbing my throttle side fork tube so I pulled them apart and holding the fork legs next to each other one was definitely longer (the spring) so I pulled everything apart put in the delrin bushings and unscrewed the spring ends and than springs were same length side by side. Put it all back together and they were same length. Reason why fork tube was twisted is because they had top spring deal tab180 from where it was supposed to be. I put it all back together and tubes measured same length. Bolted axle in with wheel than it did same thing tire rubs throttle side rubber dust cover. Wtf is going on
Maybe you need to change wheel bearings
Just the stuff off the top of my head GL
