05-25-2011, 04:44 AM
Indeed sir
Fawk you vortex cap
Indeed sir
05-25-2011, 04:46 AM
they make a "metal tank repair" 2 part putty you can get at any auto parts store that is the biznisssssssss
05-25-2011, 05:06 AM
Yep I use quick steal because u can form it to how u need it and it's like steal after it sets... It's sandable paintable and u can drill and tap it if need be
05-25-2011, 05:08 AM
05-25-2011, 05:30 AM
stock cap takes care of the problem.....
05-25-2011, 07:10 AM
05-25-2011, 07:25 AM
05-25-2011, 07:30 AM
if you have the type of vortex cap that has the little check ball in it take out the little ball and spring from the base then seal the base to the tank with a rubber gasket ...
the ball and spring always end up sticking allowing pressure to build in the tank and that pushes out almost any gasket but if the ball and spring are gone any pressure will bleed out the over flow ..
05-25-2011, 08:36 AM
i had that problem on old f4i...i put a big "o ring" from a washtud/shower drain around the base (way thicker then the vortex one) then I took a grinder to the base where the pegs stick out where you would run your allen bolts down and took a little material off so the base would sit down and be a lil countersunk in tank...worked good!
