what could have caused this?
#71
I have to give you credit for your resolve..lol
Reading and following the directions in a repair manual will probably save you alot of time and effort.
i always take my laptop when i go to the garage and have the manual opened - otherwise i wouldnt have known about the torque values
Sounds to me like the clean air mod was done incorrectly, when done correctly it will actually create a vacuum in the crankcase, not pressure.
This is a guess but it sounds like maybe some one didn't unplug the electric valve when they did the clean air mod, the valve needs to be unplugged to stay open or the system will build pressure.
THANK YOU OMR!
I did the Clean air mod in 2007 and never unplugged that valve...until today. BTW what would have been some other symptoms of over pressurizing the case?
Quote Originally Posted by hajinomoto1
THANK YOU OMR!
i think that was my problem as well ..
the stock part that i used instead of a T tube was closed, so OMR probably is right
as always
anyways ... I fixed the damn thing! took it out for a ride in the weekend and the bitch runs!
not as good as it was running before, but it runs
for how long ... no idea
Quote Originally Posted by adichino
as always
Congrats! I guess I lucked out; I used the correct t-valve and avoided damage for 5 years lol.
