Stuntride motorcycle Stunt bike set up (for beginners)
#51
HEL Performance Brake Lines :
HEL Performance specialise in the manufacture of all stainless steel motorcycle brake lines and hoses in over 65 countries around the world.
With over 3,800 stainless steel brakeline kits and a large range of oil cooler and stainless steel oil line kits we are sure there will be something in our range for your motorcycle.
The most powerful part of your motorcycle is not the engine - it's the brakes. That's a fact! Consider this - A GSXR1000 can do a standing quarter mile in 10.8 seconds with a terminal speed of 138mph - the brakes can do the same amount of work, but in reverse, in just 6.8 seconds - and by fitting HEL Performance Stainless Steel Brake Lines you can make them even more powerful.
HEL will NOT sell Aluminium Fittings For Brake Lines
HEL will NOT sell Kevlar Covered Brake Lines For Your Bike
Why change your brake hoses?
Despite what the salesman tells you - every modern motorcycle has compromises normally instigated by accountants rather than engineers. One such compromise is the materials used for the brake hoses on your motorcycle. Rubber hoses or mild steel fittings are cheap but we all know how rubber hoses bulge under pressure, are porous and allow the brake fluid to absorb water vapour from the atmosphere and that mild steel fittings rust.
[ame="http://www.youtube.com/watch?v=2_jhSp8YpfI&feature=player_embedded"]YouTube- HEL Performance Brake Lines - Voice Over Company Overview[/ame]
www.helperformance.com
Spark Plugs :
Typical Motorcycle Sparkplug
Motorcycle Sparkplug Maintenance :
Tip: Correctly reading a spark plug can save you a lot of time and money.
Sparkplugs Types :
You may of noticed that there are hundreds of types, sizes and brands of spark plugs on the market. But out of that huge selection, only a handful will work with the motorcycle engine you own. Also different brands (NGK, Bosch, DENSO, Champion, Esc) will work better on different types of engines.
As a general rule of thumb, use the sparkplug your manufacturer recommends for your motorcycle (same brand and part number). Unfortunately some spark plugs are very specific to a type of engine and make only for that engine such as the NGK ME8 for $34.23 per sparkplug, compared to the "normal" price of $2-4 per sparkplug.
Reading a spark plug correctly: (Clickable chart) :
There are two different main ways to read a spark plug. #1. The first way is to just unscrew it out of the engine and take a look at the end of it, matching the chart below. #2. The second way is the same as #1 except you go for a really hard high revving ride on the bike, pull over and then unscrew each plug to read them. (Just make sure to use gloves as they will be very hot).
A spark plug can easily and quickly tell you the condition of an engine (good or poor), how it is running (rich or lean) and how much it will cost to fix it.
CARBON DEPOSITS :
Symptoms: Dry sooty deposits indicate a rich mixture or weak ignition. Causes misfiring, hard shifting and hesitation.
Recommendations: Check for a clogged air element, high float level, sticky choke and worn ignition points. Use a spark plug with a longer core nose for greater anti-fouling protection.
OIL DEPOSITS :
Symptoms: Oily coating caused by poor oil control. Oil is leaking past worn valve guides or piston rings into the combustion chamber. Causes hard starting, misfiring and hesitation.
Recommendations: Correct the mechanical condition with necessary repairs and install new plugs.
TOO HOT :
Symptoms: Blistered, white insulator, eroded electrode and absence of deposits. Results in shortened plug life.
Recommendations: Check for the correct plug heat range, over-advanced ignition timing, lean fuel mixture, intake manifold vacuum leaks and sticking valves. Check the coolant level and make sure the radiator is not clogged.
PREIGNITION :
Symptoms: Melted electrodes. Insulators are white, but may be dirty due to misfiring of flying debris in the combustion chamber. Can lead to engine damage.
Recommendation: Check for the correct plug heat range, over-advanced ignition timing, lean fuel mixture, clogged cooling system and lack of lubrication.
HIGH SPEED GLAZING :
Symptoms: Insulator has yellowish, glazed appearance. Indicate that
combustion chamber temperatures have risen suddenly during hard acceleration. Normal deposits melt to form a conductive coating. Causes misfiring at high speeds.
Recommendation: Install new plugs. Consider using a colder plug if driving habits warrant.
GAP BRIDGING :
Symptoms: Combustion deposits lodge between the electrodes. Heavy deposits accumulate and bridge the electrode gap. The plug ceases to fire… resulting in a dead cylinder.
Recommendation: Locate the faulty plug and remove the deposits from between the electrodes.
NORMAL :
Symptoms: Brown to grayish-tan color and slight electrode wear. Correct heat range for engine and operating conditions.
Recommendations: When new spark plugs are installed replace with plugs of the same heat range.
ASH DEPOSITS :
Symptoms: Light brown deposits encrusted on the side or center electrodes or both. Derived from oil and/or fuel additives. Excessive amounts may mask the spark, causing misfiring and hesitation during acceleration.
Recommendation: If excessive deposits accumulate over a short time or low mileage, install new valve guide seals to prevent seepage or oil into the combustion chambers. Also try changing gasoline brands.
WORN :
Symptoms: Rounded electrodes with a small amount of deposits on the firing end. Normal color. Causes hard starting in damp or cold weather and poor fuel economy.
Recommendation: Replace with new plugs of the same heat range.
DETONATION :
Symptoms: Insulators may be cracked or chipped, improper gap setting techniques can also result in a fractured insulator tip. Can lead to piston damage.
Recommendation: Make sure the fuel antiknock values meet engine requirements. Use care when setting the gaps on new plugs. Avoid lugging the engine.
SPLASHED DEPOSITS :
Symptoms: After long periods of misfiring, deposits can loosen when normal combustion temperature is restored by an overdue.At high speeds, deposits flake off the piston and are thrown against the hot insulator, causing misfiring.
Recommendations: Replace the plugs with new ones or clean and reinstall the originals.
MECHANICAL DAMAGE :
Symptoms: May be caused by a foreign object in the combustion chamber or the piston striking an incorrect reach (too long) plug. Causes a dead cylinder and could result in piston damage.
Recommendation: remove the foreign object from the engine and/or install the correct reach plug.
SPARKPLUG CAPS :
Tip: Don't use decorative or spark arching type sparkplugs.
There are many different styles and types of sparkplug caps. Try to use the sparkplug cap that best matches the angle between the spark plug wire and spark plug itself. No matter what shape the spark plug cap is, is will perform the same.
Try to avoid "decorate" or spark arching type spark plug caps as they will LOWER the power to the sparkplug and you will have a weaker spark on stock systems.
Types of Motorcycle Spark Plug Caps
SPARKPLUG GAP :
Tip: If you use the exact same sparkplug as your motorcycle manufacturer recommends the sparkplug should be (99%) properly gapped to the correct size. Checking a gap only takes seconds to do.
Always check that the spark plug gap is compatible with the engine manufacturers specification. A gap that is too small means that the spark duration will be very quick and the spark will be thin and weak. The consequences of this may be bad starting and high exhaust emission levels. This will result in an increase in fuel consumption. If the gap is set too large, the ignition system will not be able to cope with the demands and a misfire situation will occur. Some wide gap spark plugs have a longer ground electrode to accommodate a wide gap setting. These must be used where specified, as opening up a standard plug to a wider gap setting may result in the electrodes not running parallel to each other. This could result in abnormal and premature electrode wear.
HOT AND COLD SPARKPLUGS :
Tip: It is better to fix the problem than to change the sparkplug to patch it up.
Why Hot and Cold Sparkplugs? Using a hotter or colder sparkplug can be just the fix to an engine problem. Very basely, if your motorcycle engine is running hot then try using a colder plug, if it is running hot try a colder plug.
NGK diagram showing insulator and heat range
HOT PLUG :
- has a longer insulator nose length
- less heat is absorbed by the plug and transferred to the cooling system
- the plug runs at a higher temperature
- the plug is more prone to pre-ignition (if greater than 850 degrees C)
- NGK BP5ES is hotter than a BP7ES plug.
- An overheated plug will be white with brown spots.
COLD PLUG :
- has a shorter insulator nose length
- more heat is absorbed by the plug and transferred to the cooling system
- the plug runs at a lower temperature
- the plug is more prone to fouling (if less than 500 degrees C)
- NGK BP7ES is cooler than a BP5ES plug.
- A fouled plug will be black and sooty.
Spark Plugs :
NFLUENCES TO SPARK PLUG TEMPERATURE :
Following situations can increase spark plug temperature:
- Lean air/fuel mixtures
- Increasing compression
- Forced induction (Supercharging, turbocharging or Nitrous)
- Camshaft change
- Advancing ignition timing
- Higher engine speed
- Higher engine load
- Lower air temperature (more dense air resulting in leaner air/fuel mixture)
- Lower humidity (more dense air resulting in leaner air/fuel mixture)
New SI cage design :
The first pic is the old cage with the small diameter mounts.
This pic is the updated cage with the larger diamater moutnts.
Last pic is a comparison between the 2.
Install will be much easier! That and removal after a bunch of nasty hits.
RIGHTEOUS STUNT CLUTCH LEVER (UPDATE) :
Close-up of the Bead Blasted finish :
Close up of the Raw finish :
Close up of Bling :
RK Armors :
myspace.com/rk_armor
For help and questions just send PM here :
http://stuntride.com/vbstunt/private...o=newpm&u=3456
HP POWDERCOATING :
“For all your powder coating needs.”
We can coat any product that can withstand 400 Degrees Fahrenheit.
Car / Truck Parts (Pulleys, Alt Housings, Intakes, etc), MotorcycleParts, ATV parts & much more.
What is Powder Coating?
Powder coating is a process where a finely ground powder is sprayed at very low pressurefrom an electrically charged gun. Then cleaned and bare metal part is grounded. The gunis charged From 10kv-100kv to give the particles a very high electrical charge. The particles are instantly drawn to the part, adhering to the charged surface. The part is then baked (high-temperature cured) and, as soon as it is cooled, is ready to go. Powder coating, as it is a thermo-set finish, is great for high heat items such as exhaust manifolds, headers,and barbeques.
Instructions for coating preparation :
Item must be disassembled prior to shipping(no plastic or rubber parts attached)
Item must be metal or aluminum and able to withstand the 400 degree bake cycle
Greasy items are subject to an additional cleaning fee
Powdercoated or painted items will require additional fees for chemical stripping .
Motorcycle/Atv Price List
Sportbikes :
All prices include the following.
Stripping/sandblasting parts, cleaning/outgas parts
prep & Powder coat
All parts must have any bearings/seals removed
Prices shown are for single solid color's..
For Candies, Metallics & Extra Clear coat Ad 25% to prices listed...
I will also offer Discount on Multiple parts & or Complete bike Package price..
$225 Frame
$50 Swing-arm
$45 Subframe
$35 Swing-arm Bracket
$120 Wheels- set
$25 Front Brake rotor,each-center's only
$25 Rear Brake rotor,each-center's only
$40 Fork Tubes,pair upper
$45 Fork's lower legs Pair
$60 complete rider set with heelguards, rear set's, brake, and shift levers
$25 Wheel hub/sprocket carrier
$25 Tripple Clamp upper
$20 Tripple lower
$15 Brake caliper bracket,each
$20 Brake caliper (1pc). each
$30 Brake caliper (2) pc, each
$25 Clutch cover
$25 Stator cover
$15 Rear sprocket
Ceramic Exhaust price's...All colors
$110 Header
$40 Muffler
Sportbike Frame & swing-arm
$250 for single color.
$300 for 2 part metallic or candies
Wheels per set
$100 set in single color
$150 set in metallic or candies
$200 Two tone colors
Atv/ quads
Frames
$225 single color
$350 metallic/ candies
Wheels
$25 each single color
$35 each metallic/candies
HIGH TEMP CERAMIC COATINGS.
CHROME 1300-DEG.
WHITE 2000-DEG.
TITANIUM 2000-DEG.
BLACK SATIN 2000-DEG
CAST IRON 2000-DEG.
ALUMINUM 2000-DEG.
2"-3.5"
TUBING $15.OO PER FOOT.
PRICES BELOW FOR OUTSIDE,AND PRICES FOR INSIDE & OUTSIDE/COMPLETE.
4-CYL Outside COMPLETE
STOCK MANIFOLD $65 $90
HEADER $75 $95
8-CYL STOCK MANIFOLD $125 $150
TURBO/SHORTIE'S $150 $175
LONG TUBES $200 $250
HP-POWDERCOATINGS is located at :
3636 Thyme Dr., St.Charles , MO 63303Phone: (636) 936-8051
http://hp-powdercoatings.com/
Email us at: Tim@HP-Powdercoatings.com
WRP :
Handlebars and Accesories : (Click for open or Download)
WRP Brake Discs & Pads :
WRP Driveware :
www.windtrading.it
STAR ROTORS :
www.starrotors.com
