SS Plates for WR250X Stuntas
#41
im going to bring my bike over this week and we can figure out the fan issue and over heating. and ill pick up plate then!
sounds good ill be around anytime after 5 durin the week
Plates are ready to ship guys, if you stunt a wr250x and dont have one you need one, world of different, perfect setup for lot stuntin
looks real good, i got it in the mail 2 days ago. Thanks Homie!!!
i'll try to put in on this week end if i have time. now i just need to be able to fully use my left hand to try it out, i have 4-6 weeks still to go.
i threw in some bolts for ya that i think should work, i believe you can fit a 3/8" bolt threw the holes perfectly but i didn't have my bike torn down to figure out exactly what is needed for length, mine has brackets mounted underneith the sub that holds my undertail exhaust on so mine is gonna be different than everyone elses. should be a piece of cake tho really.
post up pix when you get it mounted up.
yeah, i saw that. thanks man!
it shouldnt be too bad, but i do have my subframe cut up and reinforced with steel plates and bars since it was bending up so bad from hard loops...lol. not sure how it will work with my under tail, but i think i had that bracket cut out and replaced with a steel plate.
i forget exactly, but i'll figure it out. might mess with it this weekend, but im just not in a rush since i cant use it til my hand heals. i'll def post up some pics when its done.
yeah should be pretty easy to get figured out tho, ive only ever tapped my sub but mines got the shorter style roundbar on it so itll go past 12 o clock before it hits, i ony reinforced a couple of corners on mine but so far so good
got mine today! this thing is awesome and a must have for any wr250x stunt rider. super high quality and bolts right on!!!!
SS plate installed, cant wait for my finger to heal up and try it out!!!! turned out really sick looking!!!
check out the tread below for a buch of before and after pics
http://stuntride.com/vbstunt/showthr...29#post1313829
got a few left who else needs one, must have for the wr250x
