07 zx6r wheelie heelp
#21
\r\n \r\n ok first off wear your gear... protect yourself then the bike...
\nsecond i dun know how others feel about it but i use one finger to pull in clutch it kinda limits to just the right disengagement, then i go about 2/3 throttle... and dump the clutch .thats about it keep trying little bits of throttle more n more to u hit the sweet spot no need to rush... and you might want to do sit downs till you can manipulate the bike left n right from a sit down position and dun forget to listen for the yut uhhh the bike makes on the way up lol\r\n
\r\n Originally Posted by DclarkJr\r\n View Post\r\n
i just had a tune up on my bike but i will check the chain and see if its loose.so should i pull the clutch all the way in then rev then let go of the clutch and should i be in the power zone around 6 0r 7 grand or should i be less with the rpms
\nrpms are not important cause body position and center of gravity effect the rpm\'s need edto lift... example if you bounce the bike and n dump clutch you will not need as many rpms, or if your on rear pegs or staggered it will very... take baby steps once the basic concept is down you\'ll be murdering them wheelies
\n\r\n
\r\n Originally Posted by GixxerJamie\r\n View Post\r\n
Don\'t tell a kid that can\'t wheelie that it comes up easier on the rear pegs\r\n
\r\n Originally Posted by Highstyles\r\n View Post\r\n
2 points to you sir\r\n
\r\n \r\n i retract my statement dun try rear pegs till u perfect sitdowns or u may need a tail bike or worse sorry guys
\ncover that rear brake so u dun loop your shit\r\n
still, Don\'t try them until you have a handbrake installed, Thus trying them now shall leave you butt bruised, body rashed and bike trashed!\r\n
\r\n \r\n thanks guys i am doing baby steps some things work some dont but i wont give up!!!!!\r\n
\r\n \r\n when i started my prob was when the bike would come up i would lean forward cause i was scared.....i found locking my arms straight helped me not jump to the front when i clutched it.....just practice. its like anything just takes time....before u know it u wont even be thinkin about it\r\n
\r\n Originally Posted by Reaper\r\n View Post\r\n
Search torrent\'s for, "wheelis for dummies" and "advanced wheelies for dummie\'s"
\nno joke they are out there, try isohunt first, i think thats where i downloaded from
\nKyle will love that...lol\r\n
\r\n \r\n learn on a small dirtbike or atv first. if you absolutely must learn on your minty stunner piece...... get going about 15mph, and lightly pop the clutch with minimal throttle, just get the bike a foot off the ground and get used to feeding a gentle input of throttle to keep it up, try to be fluent about it, once you get it up 1 foot and keep it there for lets say 20-30 feet, let the front end gently come down. as you get into taller wheelies you will have to let off the gas a bit to allow it to come down and as the wheel gets closer to the ground you want to accelerate again to set it down gently. and please pull in the clutch once the wheel is on the ground, its so annoying when people let the bike scream in 1st gear.
\nyou just need to practice from that point, gentle pop of the clutch to get it up, ride it out, and each time you do it, try to ride the wheelie out a few more feet in distance. when you feel comfortable, allow the bike to come up a little taller. if you can still see the road through your windscreen, you are still right below balance point, so dont get scared.\r\n
