Threads: 8
0
Damn i figuered at the 50-60 mark you were near blowing the tire up... shows how much i know about tires pressure though.
Threads: 2
0
can you do no hander circels on that 70psi tires?
i always ride between 50 and 65, i always start high, than i reduce pressure till its at the point that the nohanders aint falling in the circel.
also there is a lot of difference in tires.. race tires i use a lot off pressure but when you use a pilot road 1 (my favorite, than i can go as low as 36psi before it starts to feel strange
Threads: 1
0
cool thanks bros im around 32psi, anybody know the pros n cons on the d616, and why some people run there tires backwards?
Threads: 1
0
over 50psi i start to wonder if my face will be blown off! ctfu
Threads: 0
0
D616 are awesome in rain clutching up in the rain like a beast dipping through dirt back ally's from chp they hook up great when u need it to an I've drifted on em a lil but It felt like the wanted to grab a bit more than tires with more contact (less grooves ) but I'm also getting used to my drifts again after finally flipping my clip ons just my opinion
