Keo F4i Tank Build
#21
\r\n \r\n Made a spacer for between the top of the rea shock and the frame out of 1/2 inc steel today at work, only took about 5 min and 20 to put on and I now have plenty of room for the tire to bottom out and not smash te 1000rr exhaust. FREE! I love saving money!\r\n
\r\n Originally Posted by Outlaw_FTP\r\n View Post\r\n
And if Kevin was behind you where the F is the footage!!!
We just going for a cruise and as curvey as these roads were I wouldn\'t have been filming anyways.\r\n
\r\n Originally Posted by EvilTwin\r\n View Post\r\n
\nYeah can\'t film everything, that wuld cost a fortune, and leave little fun for the person behind the camera all the time\r\n
\r\n \r\n Will the spacer you made work on the two seater???\r\n
\r\n \r\n I believe it does, look where your shock mount comes through your frame, if you have an extra quarter inch of thread on the other side you have a quarter inch to add on the shock side, depending on how high you want to go, I had a quarter inch free so I just have a 1/4 inch block of steel with a hole drilled into it to use as a spacer. Washer would work but Id assume you would want something more solid if its going to take a beating\r\n
\r\n \r\n Put the tail, tank, frame, and fairings in to be sprayed pearl white, and the rest is for me to paint red. pics as soon as I get to see it\r\n
\r\n \r\n Did a few more things so I\'ll post
\nCut off my lower part of the headlights because they sucked. I am using glue and the remaining screws to re assemble it. I will use h7 powered fog lights as seen. Fog lights will be bolted to the lower tripple with a simple "L" bracket
\nLoose mounted to the front end. now I just need to get some things back from paint and start painting the red soon
\nFrame Looks good after one coat, I\'m excited to ride!\r\n
\r\n \r\n get that thing together buddy\r\n
\r\n \r\n Worked yet another weekend on the bike so heres some more pictures!
\nSteel mesh put behind the KEO
\nSpraypainted the red, running outa money
\nWhite paints done!
\nLittle extra touch.
\nSpraying a clear over the reds today and starting to assemble the bike. still waiting for a few donation parts because I am now poor\r\n
\r\n \r\n When u make that lift for ur shock, u needa weld ur 1/4 square to the original mount on left n right side cus it butts against the lip on the frame and if u just slap a washer or spacer in the shock will spin around and rip ur hose off.. I hada redo mine when someone told me bout it, I looked at mine and sure enough it was turned almost 90 degress already. I grinded the head off the original mount and put a new bolt 3/4in longer thru and spot welded it in and grinded it to clear the top of shock. Then made my spacer out of 1/2in steel and welded down both sides. Its super solid and bike sits more like a 636 or 600rr now.\r\n
