Threads: 0
0
\r\n \r\n I went -1 in the front and +2 on the rear i also installed a FI cage to help protect the bike some. so were should my rpms be when trying to clutch it up i got the front wheel up mabey a foot then lost it and now its like it dont wanna come up\r\n
Threads: 19
0
\r\n \r\n once you have it up, stay on it, learn the feeling before you worry about balance point and catching the bike with your rear brake. pucker your butt and go for it.\r\n
Threads: 0
0
\r\n \r\n Ok i will give that a try if it ever stops raining\r\n
Threads: 0
0
\r\n \r\n ok i got my bike to wheelie mabey a foot off the ground but cant get any higher i dont think i am clutching it up right! i need some advice on the clutch or somthing please help!!\r\n
Threads: 0
0
\r\n \r\n i just had a tune up on my bike but i will check the chain and see if its loose.so should i pull the clutch all the way in then rev then let go of the clutch and should i be in the power zone around 6 0r 7 grand or should i be less with the rpms\r\n
