01-30-2013, 01:46 AM
Tires & pressure?
01-30-2013, 02:55 AM
I'm running 18 psI....it gives me the power to do slow wheelies in red lights...yes with the cold and all that...but it suck when I go in the highway...when it gets warm I do 25 psi most of the time
01-30-2013, 05:51 AM
01-30-2013, 05:51 PM
Take offs from the local dealer @25 psi, ive tried every pressure between 0 and 35, i found that the higher pressures the bike tends to "fall" into a circle......i like the stability of 25! 0psi was fun too tho.....you could jump off the back of that bitch with it on idle and it would still go straight!
01-30-2013, 07:52 PM
Whatever psi is recommended by the manufacture works good for me
01-30-2013, 08:34 PM
01-30-2013, 10:57 PM
I gotta disagree, my race tire hooks up fine. http://youtu.be/07zVGSfirNE
01-31-2013, 11:23 PM
02-06-2013, 12:32 AM
Im rollin on 35psi on some used patched up crap. Once its roasted off im buyin a Dunlop D616.
02-06-2013, 02:45 AM
Pilot road. 28psi or shitty vee rubbers that constantly leak air...start with 30 by the e.d of the day im on the rim
