636 deaths from tranny
#11
F4i forever!!!!
I saw the title and thought your bike may have been killed by a transvestite, not the case at all, might have made for a better story
yeah, im sure your shift dogs and forks are startin to wear out. not too hard to replace, i have a stack of 05-06 trans in case of emergency
Quote Originally Posted by krazykyle85
so.. im too lazy to find apexs post about 636's expiring.. but im sad to say that my tranny has started to go now. thank you mr brocha for speaking of things that should never be spoken...
is it normal for a tranny to shift into nuetral when i apply the slightest pressure on the shifter when on the gas? mid rpm range.
it happens whether i apply pressure up or down on the shifter, and only around mid RPM range. like if i am at a stop, apply generous throttle and then barely rest my foot on shifter around mid rpm range pops into nuetral.
tranny problems make me sad..
and by tranny i dont mean the ones that pitchita introduced me to in barcelona..
mine is shifting into neutral with OUT any pressure on shifter, unless the winds that strong, it seems to do it when rpm's hit a certain range on my bike, someone keep track of how many times my bike goes into neutral this weekend in nashville
i blame nick for speaking of this as well
Quote Originally Posted by BOYD
get another trans and set of shift forks asap boyd, it starts at higher rpms but soon it wont stay in gear at all.
DANNNNG! that is suck assy
thats a dick suck you cant make nashville..... wrench wrench wrench... best of luck killa
yup..you dont wanna stunt it with a gear slipping out..it starts only under torque,after about 3 days normal riding it went from slipping only above 8k to slipping when id release the clutch..popping out of gear in a fast wheelie will mouse trap you with the quickness
Yes, it is true, I found the writing inside the case on 2 out of my 3 motors.
4/23/10
5/1/10
We're all on the way out
Quote Originally Posted by Nick Apex
4/23/10
5/1/10
Quote Originally Posted by armenian.
that shit happens to my 05 sometimes...as soon as it slips into neutral, i have the clutch pulled in, and when i try to put it in gear, it makes a "clackalacking" noise and the shifter kinda vibrates. really annoying.
i have never ridden a 05-06 that doesnt do that hell even my gixxer 1000 did that
