04-30-2010, 03:56 AM
hey I just picked up 06 zx6r forks and want to use my 03 636 rim........... would 04-05 zx10r rotors work i fucking hope so
would 04-05 zx10r rotors work on swap?
04-30-2010, 04:02 AM
I believe so. I think you need 280mm.
04-30-2010, 04:07 AM
im not so sure about this. i have a 05 zx10 front end on my 04 6durty. i know the 05-06 636 and 04-05 zx10 rotors are interchangable. the 0304 rotors are smaller. try it. if everything bolts up you should be fine
04-30-2010, 04:09 AM
see I heard the bolt pattern is the same but its the size of the rotor im worried about
04-30-2010, 04:13 AM
The forks determine which rotors you run. I have 05-06 6 rotors on my 03 6 with 08 forks. You should be fine.
04-30-2010, 04:18 AM
I ordered it think it would work but I guess ill find out
04-30-2010, 04:25 AM
if the bolt pattern is the same your good. theres only 2 different sizes. the smaller 03 04 and the larger ones that came on the 05 06 (the same as the zx10) i just put 05 06 636 rotors on my zx10 forks bc the zx10 rotors were loose. i know they are floating rotors but you should not be able to move them back and forth a quarter inch.
04-30-2010, 04:26 AM
^The 08+ 10s have even bigger.
04-30-2010, 04:31 AM
04-30-2010, 04:34 AM
I haven't seen any for sale... if you already have an older front-end you could run the 08 10 rotors along with a spacer for the calipers and be all set.
