all out f4i rebiuld 2.0
so that's how it was without all the bracing
and that's how it is now without the upper subframe mount
and with them
i might add a gusset in the back, i don't know
and i'm thinking about reenforcing all the back of the motormount and the swingarm pivot with a 1/8th of an inch thick plate like this, just with a better fit to the frame. at the same time i could use the as an ancor for my rearsets.
Looks good
Sent from my iPhone using Tapatalk
Frame looks badass u got skills man
Sweet! Sub'd...
Nice frame, good job
frame looks great. u building ur own subframe too?
I'm just gona modify the subframe i built last year, it did great and i don't see why i should change it. I'm only gonna modify it so the pegs on it are going to be a little higher and i want to fit a real backseat on it with a roundbar under it
Wanna make a frame for me??? If so, how much? If not, it was worth a try! Lol
I don't know about that yett... I need to finish it, test it, then i'll know. I dont even know how much its worth. How much would you be ready to pay for something like this ?
that is a gorgeous frame you should defiantly start slangin those
