full Hayabusa front end.
this is a minnnnnttttyyyy front end from an 06 Busa. forks, triples, rotors, caliper, master, wheel and axle, and handle bars, steering stabilizer and ignition. i will disassemble it so it would be cheaper on shipping. i was planning on using it but i really need money so ill have to delay the fork swap on my bike.
650$ and YOU pay for shipping. FIRMMMMM.
Has anyone done a front end swap with these before? Never seen it. Would be sick
i was gonna put them on my 600rr and give it a try, all it takes is a steering stem swap and the right size bearings.
Interesting
i saw a hayabusa front end on a 03/04 in the classifieds section a while back.. so i know it has been done
good luck with the sale!
Quote Originally Posted by SQUINTS
only problem i see with doing the swap, is the weight you'll be adding, the busa forks are heavy and the wheel is heavy. but on the plus side, u get the humongous brakes (endos )
bump
bump.
bump
sold
