Threads: 43
Put the radiator cap back on.
Threads: 14
Step one find out where its leaking from lol
Threads: 55
loose hose? hole in the radiator? loose radiator cap?
might just be overheating and steaming out through the vent. can't really diagnose anything based off of your description.
Threads: 5
what temp ur bike runnin at when this happens?
Threads: 27
Could be a loose cap or mis adjusted cap. Mine was leaking last weekend. Let it cool, popped the cap off then popped it back on and it stopped.
Threads: 6
check your coolant overflow res. sounds like maybe its leaking from there and then touching your exhaust pipe and smoking, just a thought..
Threads: 11
Thanks a lot guys! I took a look under the bike and it appears that a hose feeding the radiator it's broken....Tomorrow I'll take off the plastics and cage to take care of the problem.
