05-26-2011, 02:47 AM
but you did the opposite of what taking the ball out would do
it will be ok if the filler hole can vent to the well around it but if the filler hole is sealed then you may end up blowing out some thing , from what steve tells me the f4i tank vents internally so theres no need for a vent on that but most other bikes need a vent
