Houston.....Houston? Anyone?
Quote Originally Posted by Stunt Heavy
so whos riding this time of year? lost my 636 key in the move so i need a lock set, but ill come play on the supermoto
You don't need a lock set you need a locksmith. They will make you a key. Just call around places.
ive had bad luck with locksmiths.. 40 or 50$, ended up with a shitty fitting key that worked in the ignition, but not the tank or undertail. for double that I could get a lockset.
