SIX piston big rotor!!!
Quote Originally Posted by GIL with 1 L
These also work on the fti dual quad bracket and cover way more surface then the f4i caliper
JoeyT put his on the dual quad and said it was easy but has some pad overlap....
Quote Originally Posted by Raider
look at that cute little rotor!
oh shit! im running the older zx6/9r 6 piston. the gsxr looks real close and is a tokico but has a much much different way of bolting up....dont laugh at the #ghetto fab.
Quote Originally Posted by bdhstunt
so just a lil mod till your bracket an it bolts up
no mod to the bracket, only to the caliper
This is the ONLY mod necessary to make it fit. The little relief just above there bottom bolt hole. I didn't want to mess with the bracket just in case it didn't work out.
any mod for FTI dual with the gsxr?
Quote Originally Posted by DoWheelies
Nope .doesn't even come close to the rim at all
Joe said he just had to shave a couple spots on the caliper. If he can do it anyone can do it, LOL.
very interesting stuff happenin here
If by interesting mean amazing then you are correct Sir!
