01-09-2010, 08:28 AM
My bike seems to be missing the spacer on the axle in between the swingarm and the sprocket, just on the left side of the wheel there. Can someone tell me how wide that spacer is so i can get something in there.
crf50 rear axle, wheel spacer question
01-09-2010, 09:10 PM
It is 1 inch long .
But the outer diameter and wall thickness of the spacer has to be correct because it has to fit thru the bearing seal and push against the bearing correctly . It also has a shoulder that's wider on the end to push up against the swingarm . Just go order one at honda . It's like $6 . Or you can buy a 50stunt sprocket guard and it has the spacer welded to it . |
