09-11-2015, 03:10 AM
I'm parting out a complete F4i stunt bike. Shoot me a text at (314)795-7178 if your interested in something as I do not regularly check the forum. Parts are located near Detriot for local pickup. I can also ship anything.
Motor: 10,000 miles with ignition advancer and OnPoint oil pick up.
Stunt Tank: Custom welded stunt tank with vortex gas cap
Frame: clean title will go with frame
Sick Innovations Scrape bar:
Blindside Armor Subcage:
OEM seats, OnPoint Step Plate:
Sub Frame: Straight
Rear wheel, tire, rear rotor, 60 tooth sprocket, hub and cush drive:
Hohey designs Streetfighterz Bracket:
F4i Saggy Ass Fix:
Hohey designs billet rear sets:
Sick Innovations Cage: slightly bent
Stock Chopped Exhaust:
954rr front wheel, rotors, and axle pegs: front wheel is bent
DCP Radiator Cage:
I also have all of the OEM parts like the wiring harness, shock, coolant tank, ecm, etc.
Send me a text if you have any questions.
Thanks
Sent from my SAMSUNG-SM-G870A using Tapatalk
Sub Frame: Straight
F4i Saggy Ass Fix:
DCP Radiator Cage:
Thanks
