Fuel Leaking from Charcoal Canister F4I - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: Fuel Leaking from Charcoal Canister F4I (/showthread.php?tid=9218) Pages:
Fuel Leaking from Charcoal Canister F4I - SinCalBones - 12-16-2009 Okay so while dealing with another problem with the F4I, I decided to lay it on its side in order to remove the case cover without losing oil. Well when I did I ended up losing damn near all my fuel as it started flowing out of my charcoal canister.......... Any suggestions???? Fuel Leaking from Charcoal Canister F4I - f4ibry - 12-16-2009 i dont think it should be leaking outa the charcoal canister but more than likely your fuel overflow line from the tank check it out btw any u bakers mofos know a dude named manny riddin my old f4i? curious if its still alive these days Fuel Leaking from Charcoal Canister F4I - SinCalChevy - 12-16-2009 Yeah, I rode with Manny once. He's pretty shy, I believe he just moved here? Pretty cool guy though. Fuel Leaking from Charcoal Canister F4I - SinCalBones - 12-16-2009 Nope its comin straight out the lil tab looking thing at the front of the canister...... And I need it not to ASAP cause I need to lay the bike on its side to fix another issue FML Fuel Leaking from Charcoal Canister F4I - loogie - 12-16-2009 get a 636???
Fuel Leaking from Charcoal Canister F4I - StuntBikeJake - 12-16-2009 Bones just go to Chevy's house and get his Kawi and leave him the F4i. Problem solved Fuel Leaking from Charcoal Canister F4I - hafrak13 - 12-16-2009 when u lay the bike on its side if the tank is near full ,fuel will run out of th vent which is routed to the charcoal canister . so this is normal the charcol canister is not needed its only on california models.but if the canister is full of fuel it could cause a rich condition.it is routed back up to the throttle bodies Fuel Leaking from Charcoal Canister F4I - hafrak13 - 12-16-2009 heres a pic that may help http://i863.photobucket.com/albums/a...k137/photo.jpg Fuel Leaking from Charcoal Canister F4I - hafrak13 - 12-16-2009 try that again sorry
Fuel Leaking from Charcoal Canister F4I - CLD107 - 12-16-2009 ^^^you sir are awesome for helping this guy with a diagram. you should post in all the help threads. |
