how to get started... - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: how to get started... (/showthread.php?tid=54372) |
how to get started... - Chucklles - 01-30-2008 i want to get started on the stunt scene and picked up a 99 ZX6R to learn on. i got a SI crash cage already and sliders. with money somewhat in mind what are some needed upgrades that i should get first to get started.. Re: how to get started... - budd (SMF) - 01-30-2008 you should be all set with just a cage, you could change the gearing, get a subcage, remove your plastics until your decent enough to not mess them up, handbrake after you learn the footbrake, Re: how to get started... - JamieDubS (SMF) - 01-31-2008 dont forget a 12 bar espically when learning wheelies and learning that rear brake hitting it too hard slapping that rear end off would suck Re: how to get started... - Chucklles - 01-31-2008 hahaha... yea dont want to snap off the rear end... i thought about getting a 12 bar and changing out the entire brake lines... Re: how to get started... - budd (SMF) - 01-31-2008 plastic is more forgiving than a 12 bar, their not really needed until you can slow your wheelies down, its better to break your plastic than your subframe imo Re: how to get started... - thomas (SMF) - 01-31-2008 I had that same exact bike... dont use a bar at first u got sprockets?? Re: how to get started... - Chucklles - 02-01-2008 no not yet... take it i should... Re: how to get started... - fahq (SMF) - 02-01-2008 no not yet... take it i should... it helps a lil. you can still do wheelies on stock gearing but if you gear it a lil more it helps bring it up. |
